Thread: Split Head
Old 09-04-2006
jhampton jhampton is offline
jhampton is on a distinguished road
Question Split Head
When I purchased my Ericson 32-2 5 years ago, the inspection revealed epoxy on the head of the engine just under the alternators bracket.
The owner said a small crack was appearing and he applied this patch since the head was not under pressure, I should not worry.
For most of the life of this 34 year old engine was in brackish water, but now is berthed in salt water. I only motor 30 minutes max prior to being under sail, but I have under windy occasions (being in San Francisco) have had to motor back to save the poor souls stomachs joining me.
The problem has worsened and I have applied many high temperature epoxies to help stop this steady stream of salt water working its way into the spark plug wells. I have asked advise if I should replace the head or live with the annoyance from several boaters and mechanics. All mechanics say they don't want to touch the head, since they may cause more damage by breaking off one or more of the studs. I imagine really needing this engine and having major issues out at sea if I leave as is.
It starts right away and runs smooth; it has several hours left in it.
What risks do I suffer if I just ignore this leak and try to channel the drip to the aft? Should I bite the bullet and work on it this winter and just pay the $500+ for the new head and hope the best?
I found a good article at http://www.geocities.com/atomfour/A4Tips.html#IND%20HEAD but it sounds far too easy since three well respected mechanics will not work on my engine.
Any help would greatly be appreciated. I wanted to become a sailor not a mechanic
Jim
Nido Del Mare
Any help on prop selection would be appreciated too. I pull to the port when backing and have a very difficult time getting out of my slip.
