I have an '82 O'day 28 with a 30amp shore power system. In the last few years the double throw switch to connect to shore-side power has worked at first intermittently, depending which dock I used. Now it won't engage at any dock. The boat is primarily a mooring queen and occasionally I like to use the battery charger to fully top off the batteries.
A neighboring boat suggested that I may have a grounding problem. My questions are, where do I begin to find a grounding problem in the AC system; and do those double throw shore power switches "fatigue" or fail that often? There is power to the vessel and the polarity is light is extinguished (as should be). The DC ground is fine.
Or it could be a loose connection that is causing a short between the hot and neutral wires somewhere that is causing the breaker to trip. It might be just doing its job.
I don't think the ground can have much to do with it. The breaker controls hot and neutral only.
If I show 120V on the back side of the double throw switch, then I should assume it is the switch? And where is a good place to go for that switch?
Thanks
Okay, I have lots of shore side electrical experience. On shore you never, ever, not ever break the neutral through a switch or circuit breaker of any kind. There are lots of good reasons for this. Can someone point me to a reference on marine AC that explains why the neutral wire would be broken by a switch on a boat, as mentioned above?
For a main AC switch the hot and neutral are both opened. That way it there is a reverse polarity issue in the marina you can be assured that there are no hot wires. The individual circuits are single pole, opening the hot wire only on most boats. I say most because a friend has a French built Beneteau CC36 that uses double pole breakers for every AC circuit.
On a metal boat double pole switches are often used for all circuits, AC and DC, so when it is off it is guaranteed, for stray current reasons.
Related Threads
1.7M posts
173.8K members
Since 1990
