SailNet Community - View Single Post - Mystery Shutdown (at just the wrong time!)
post #6 of Old 11-15-2011
tommays
tommays's Avatar
I cant say for sure if your boat is wired in a standard manner or wile e coyote style which is pretty common in older A4 boats
The tack can be bad and short out the ignition so i would remove the tack wire from the coil to see how it goes
The electric fuel pump SHOULD be wired through and oil pressure switch which would not allow the pump to run without oil pressure BUT that should not affect ignition
At this point i would connect a meter with clips while its runing and see IF your losing power when it stops and work from there
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
