SailNet Community - View Single Post - Tell me about the Delaware Bay
post #7 of Old 11-15-2011
pdqaltair
pdqaltair's Avatar
I've made the passage up and down the Delware many times outside the channel
Truely, the traffic in the channel is generally light and it's easy enought to slide off to one side when big ships are coming. Close encounters aren't needed. If the visability is an thing short of fine, I parralel the channel on the Jersey side. Yes, the chop is worse over shallows, but this is only a factor on bad days.
The ugly truth is that most boats motor the Delaware, as they cannot always get the alighnment of tide and wind they want; they wait for light winds and motor with the tide.
There are a few marked shoals. A good chart is always needed. I've never seen anything different than what the charts indicate, unless near a river entrance. No different than the Chesapeake regarding watching for shallows, really, so long as your boat draws less than 6 feet.
I've never had luck with Avon. I've found DEET applied every 20 minutes (not every 3-4 hours) works. I'm also sure that different people require different solutions, just as the bugs always like some folks more than others.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
