SailNet Community - View Single Post - How low can you run your fuel tank
post #6 of Old 11-25-2011
svjobeth
svjobeth's Avatar
Originally Posted by ralopata View Post
John:
Not sure about the tank on the 34 but on the 40 the tank is baffled, which helps reduce the possibility of sucking air in a lively sea.
I agree with the previous posts about the dangers inherent in getting water and/or gunk from a low tank.
However, it's not a bad idea to find out how much USABLE fuel your tank holds. While that stated capacity may be 35 gallons, no fuel pickup can actually get every last drop. Some fuel is always going to be in the very bottom of a tank. Some sailors run their tanks "dry" intentionally and then fill them up to develop a "usable" fuel number.
On JUNO, for instance, although the stated capacity of the tank is 67 gallons, we have discovered (the hard way) that the pickup sucks air at 58 gallons.
Best wishes and Happy Thanksgiving to all,
Roger Lopata
JUNO
PSC 40 -- #46
Excellent points Roger, on determining the useable fuel capacity of fuel tanks.
Jo Beth's fuel tank is baffled.
Bill & Lisa Ballard
S/V Jo Beth
1984 Pacific Seacraft Crealock 34, Hull #16
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
svjobeth is online now
