SailNet Community - View Single Post - P26-redirect halyards to cockpit
post #2 of Old 11-28-2011
jameswilson29
Senior Smart Aleck
jameswilson29's Avatar
Originally Posted by FoggyBottom View Post
Does anyone have any photos, diagrams or suggestions on running the mainsheet and jib halyards from the mast to the cockpit on a P26? ...
The mainsheet is already in the cockpit. It is attached to the traveller which runs across the cockpit between the seating area and the outboard motor well.
On a serious note, don't do it. You would need turning blocks near the mast, winches and cleats or stoppers on the cabintop. The Pearson 26 is a great little boat as designed. The stepped-up cabin top will complicate your intended layout. Why put additional hardware through the balsa-cored deck and put stresses on parts of the boat outside the original design?
Learn to go to the mast to raise and lower the sails.
jameswilson29 is offline
