SailNet Community - View Single Post - Engine Flood Pump....Would this work ?
post #1 of Old 09-08-2006 Thread Starter
MikeinLA
MikeinLA's Avatar
OK, So I was taking a look at my new diverter valve (actually I was stalling the start of my head plumbing project) when this idea hit me. Now, this might be common knowledge, but it's the first time I thought of it. First you would hook up a diverter (Y) valve to your engine cooling saltwater inlet. The main connection going to the engine with one of the ends of the Y going to the inlet and the second end of the Y connected to a hose running to the lowest part of the bilge. In an emergency where you blow a thru hull or worse, hole the boat, you could turn the diverter from the inlet side to the bilge hose side have the engine act as a bilge pump. I'm not sure of the flow rate or if it would be worth it, but would it work? OK, I'll get on that head project now.
Mike
MikeinLA is offline
