SailNet Community - View Single Post - It Usually Means Something
post #6 of Old 12-01-2011 Thread Starter
WanderingStar
Thank you all for your advice. I put a new impeller in this spring, though it might have been flawed or I might have made a mistake on the install. I will check the flow after replacing the hose. I also changed the zincs at that time. I'll check there too. The pressure in the leaking hose was high enough to shoot a stream to the overhead.
WanderingStar is offline
