SailNet Community - View Single Post - Jack lines and tethers
post #25 of Old 12-02-2011
celenoglu
celenoglu's Avatar
Jacklines should be well away from the sides of the boat. They are intended to keep you on the boat, not to drag you in water. If you fall in the soup, it is best to cut the line. Make sure your safety line keeps you on the boat if you loose your control.
celenoglu is offline
