SailNet Community - View Single Post - Quick Q's for purchasing a boat this weekend?
post #4 of Old 12-03-2011
killarney_sailor
Bristol 45.5 - AiniA
If the deck is not too high where the Tanzer is I would get the two guys (or borrow some more weight) to heel the boat so you can see what the bottom is like. Generally the part just below the waterline will be the worst. If the owner will let you, scrape away the crap down to the glass in a small area (4" by 4") to see what you can see. My sense is that blisters are likely to happen in the first ten years or so and both of these boats are older so it should not be a big issue.
One boat has a trailer and the other not? If so, you have to figure out how to get the other one home if you go that route. Someone mentioned prices - New England to Chesapeake prices tend to be higher than further south, but the boats are out of the water for a good part of the year so they are 'newer' in a sense. Also I get a sense that people in the NE tend to keep their boats in pretty good shape.
Before you get to far with these boats find out what sails there are and the condition. You probably will not be able to tell much about the shape but you would be able to see if they are in good shape physically.
Good luck
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
