SailNet Community - View Single Post - corrosion in aluminum mast - options
post #3 of Old 12-08-2011
pdqaltair
pdqaltair's Avatar
I would consider ultrasound inspection
The trouble is, you don't know how far the thinning extgends. A 1/4-inch hole may not be important at all, or there could be a large thin area. Ultrasound can also tell if the inside is smooth or rough. Of course, I do UT inspections and so this is free for me.
I would also be very surprised if the bandaid carried any important amount of load; compare the amount of missing area to the cross section of the rivets; it would take a LOT of rivets, close tolerance on the holes so that they carried load at the same time the mast began to deflect, and require a lot of drilling. Just a little slop under load, and the mast will begin to tear before patch loads up.
Is it a high load spot, and is it in compression or tension? Most masts fail by buckling up near the spreaders, not at the deck. A small hole at the deck in compression is probably unimportant.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
