SailNet Community - View Single Post - Catalina 25, 1982, pop-top; water intrusion
post #3 of Old 12-11-2011 Thread Starter
Mountaineer62
cat. 25/water intrusion
Thanks Joe for your suggestions.
Vented upper washboards may be obvious culprit; will check ports and chainplates. Assume you sail on LI Sound; Do you have k/cb or fixed keel? I have fixed keel, i.e., draws 4 feet. I am assumming fixed keel with my standard rig should point fairly well. (My C.25 is located on Ches. Bay)
Separate question: is this Sailnet site the best source for advise on repair and maintenance of Cat.25? Is there another source you might recomend?
Bob (Mountaineer 62)
Mountaineer62 is offline
