SailNet Community - View Single Post - Bomar portlights?
post #7 of Old 12-11-2011
bomar portlight repair
I've started looking into repairing my '89 vintage opening portlites.... I found out the hinges aren't standard measurements... ie. 2 lites can't be interchanged as hinges are perhaps 1/2 mm different on each port. I found lexan un-framed replacements with adjustable hinges .. haven't tried it yet on a couple of my ports this winter.. am planning to take home the most leaking ones so I can measure them better (the boat is covered /dark ... anyway the contact info for the place I hope to try is .. Jim Welinski
I'll tell you if the ports work out well... any feedback... from this list I found out that the hinges have pins that I'll try to knock out to get the portlenses away from the ports... Frank ...
frankloprest22 is offline
