SailNet Community - View Single Post - Cast Iron Keel Renovation - WS Epoxy vs. Barrier Coat first sealing layer
post #3 of Old 12-12-2011 Thread Starter
Rhodes143
Thanks. I plan on regrinding/sanding before putting OSHPHO rust inhibitor on. After this drys and hardens. I will eventually resand again once more before then immediately sealing with epoxy or a barrier coat. I did not have the keel sandblasted so getting every bit f rust off is next to impossiible, hence my use of the OSPHO, which is supposed to chemically change any small remaining rust areas into a inert material that won't rust. I hope it works as marketed.
Rhodes143 is offline
