SailNet Community - View Single Post - Cast Iron Keel Renovation - WS Epoxy vs. Barrier Coat first sealing layer
post #6 of Old 12-12-2011 Thread Starter
Rhodes143
Thanks Saildork! Do you mean to soap and water wash the OSPHO'd surface before applying the first epoxy coating? Let dry overnight or over several days, then light sand to prepare the surface for epoxy adhesion. I plan on using low density after the initial sealing layers of epoxy to fair the keel as well. I dont want to many layers because the boat will be raced and the keel needs to be as thin as possible.
Rhodes143 is offline
