SailNet Community - View Single Post - Built in safe for cruising yacht
post #5 of Old 09-11-2006
sailingdog
A safe is generally not such a good idea. Boats are generally less robust than the materials in the safe, and as such, can be damaged to remove said safe. Concealment is usually better than an obvious hiding place, such as a safe. Also, many safes are not very well thought out for a marine environment, where the salt-laden air and constant moisture will cause serious problems with the locking mechanism, if not the actual safe container itself. Safes are also relatively heavy, especially if you want a fire-resistant one.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
