SailNet Community - View Single Post - What would you buy for $15k-20k? For sailing from Florida -> Bahamas, and beyond!
post #11 of Old 12-13-2011
mitiempo
mitiempo's Avatar
David
The list makes sense but if the work is not hired out nowhere near 10k.
A quick check at Jamestown Dist shows rigging wire (3/16"), turnbuckles, and mechanical fittings for both lower and upper comes to about $1400. Chainplates need inspecting and possible replacement - figure $500. Running rigging - 3/8" Sta-Set at 1.12/ft - say 400' for $448. Autohelm about $500. Anchor rode - 1/2" 3 strand line .98/ft so $450 gets a main rode and a spare. Anchors are available used as are sails. That is $3300 plus used anchors, sails, and some yard time. If any of the above should be in a larger size add a few dollars. Still well under 10k.
Now if the op has to pay someone to do much of this it is a different story.
Brian
mitiempo is offline
