SailNet Community - View Single Post - Converting my manual windlass to electric! The math is giving me a migraine...
post #5 of Old 12-14-2011
Capt Len
So how many inches of chain move per rev of wildcat? Times 40 rpm(on direct drive shaft)divide by 12in/ft. Can you handle chain coming in at that rate? That is max no load speed. If that is too fast put the motor on low gear I would think over one hp is more than powerful either way.You still need to figure how to quick disengage the unit. Dog clutch, syncro rings from old tranny , or hex the shaft to5/8 and square the other and connect with a 1/2 drive socket.Keep the adapter plate wing nuts loose. There are many ways to haywire this together.Some will look good on the foredeck.
Capt Len is online now
