SailNet Community - View Single Post - Asymmetric spinnaker with dousing sock. Questions.
post #9 of Old 12-17-2011
BarryL
BarryL's Avatar
Hey,
My Newport 28 came with an asym kite in a sock. It was a lot of fun to use. There are a number of web sites from sail makers that have videos on how to use the kite. Do watch them as they definitely help.
It is better to have an adjustable tack line but not a requirement. You can just tack it to something at the bow, but make sure whatever you attach to is strong enough.
Make sure the sheets go outside of everything and you should have blocks shackled to the aft corners of the boat - the sheets should have as wide a run aft as possible.
Dousing is much easier if you head deep downwind and use the main to blanket the spinnaker.
My current boat doesn't have a chute and I do miss it.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
