SailNet Community - View Single Post - Very Good Vendor Thread
post #65 of Old 12-17-2011
souljour2000
souljour2000's Avatar
bebi electronics Owl LED anchor light.....mounting issues
There are three holes around the base of the PVC endcap....but not enough lip to really glue a piece of PVC pipe or any other stem/extension thingy onto very well...the holes dont really give you much "bite" when screwed into from outside into whatever pvc stem/extension one uses due to they are drilled a bit too close to the bottom of the endcap ...I sanded the PVC pipe and inside the end cap and glued them together with epoxy...seemed to work well but in retrospect...plain old PVC glue may have sufficed but I seem to grapple with an overconfidence in "the final solution...epoxy it!" syndrome...hope Bebi electronics may be checking this post and will chime in with help in this regard...its seems a great product...the OWL LED's....but too bad they cant leave a bit more room for some pvc or whatever tube to lip onto and also take screws better into the endcap with...
souljour2000 is offline
