SailNet Community - View Single Post - Asymmetric spinnaker with dousing sock. Questions.
post #16 of Old 12-18-2011
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Originally Posted by jackdale View Post
Right after the gybe is completed I check that lazy sheet is over the pulpit.
I have only ever wrapped one spin sheet, we had a short sail back to calm water. One crew member donned a wet suit and googles and we unwrapped it, not cutting necessary.
One solution to the matter of wayward assym sheets is using a single continuous sheet which reduces the need line length by about 1/3rd. We us a single 3/8" spectra sheet with the cover stripped for the last 15' on either end. This is led to through turning blocks on the aft quarters then, on each side, forward and around the headstay but inside the assym tack line (because we usually do "inside gybes") and then secured to the sail's clew. The loop of line in the cockpit passes in front of the helm between our spinnaker winches. Organized in this manner, the lazy sheet is never lost.
FWIW...
svHyLyte is offline
