SailNet Community - View Single Post - Cleaning Aluminum Spars
post #7 of Old 09-12-2006
sailingdog
Originally Posted by knothead
I wouldn't recommend painting your old spar. In a few years, maybe less, it's going to look like crap again. Actually probably worse than it does now. You may want to apply a wax or something to it while it's down but sanding will remove whatever anodizing you have left and while removing the corrosion may seem like a good idea, it's not. the corrosion is actually helping to protect the spar.
If the aluminum is pitting with corrosion, the corrosion isn't protecting the spar.
Paint will protect the spar from further damage. Properly prepping the spar with a good metal primer paint and then using either a two-part epoxy or polyureathane paint will last quite some time before requiring re-painting. It will last longer with a good paint job than it will without one at this point, based on the description.
sailingdog is offline
