I know a lot of people use preventers (Sail safe anti jibe boom preventer or a purchase to an anchor point) etc. I am leaning towards boom brakes, looked at the Wichard gybe easy (or make my own with a figure 8 descender). I have researched the Dutchman and the Walder but am curious and trying to find out more about the Scott boomlock and the new Fleming Gybomatic. Anyone out there using one of the latter two, and does anyone have any videos of them in use while jibing?
Thanks,
Richard
As a former rescue climber I would recommend any system that you can 'precisely' adjust the amount of friction that controls the 'pay-out' of the control line ... and not have to depend on the variable friction under varying wet/load conditions --- usually needing a human brain. That would in my mind more favor the Scott or the Fleming.
Id avoid a "figure-8' for any 'large' area mainsail as 1. you will have difficulty in putting 'enough wraps' on the the '8". 2. if you do get an overwrap with 'multiple' wraps its going to be a major job to get it to 'release'. 3 'strength' vs. a full loaded large mainsail is probably going to be a 'minimum'. The 'figure-8' would be 'worse' for over-wraps; the rescue-8 has 'ears' to lessen the potential of 'overwraps': Rescue 8 : Rock Climbing Gear : Rockclimbing.com
Of course any of the friction type 'brakes' are infinitely better than a rigid 'preventer' which do not allow for any 'impact' from an out of control boom or for a boom that gets 'dipped' into the water.
FWIW - I use the Wichard 'ladder type' on a ~450 sq. ft. mainsail, but find that it needs constant adjustment to get the 'right amount' of 'slip'. The Wichard supplied 'rope' is VERY stiff (kernmantel?) and is quite hard to set up precise friction.
I had a fleming 'boom brake' on the last yacht and a few months ago, I put in a wichard gybe easy on this yacht. I am very happy with this set up as I mostly sail solo and it is safe and solid. I can adjust the tension in the line.
I had installed the Dutchman on my last boat and added it to the new boat. I lead it back to a winch in the cockpit. Easy to adjust tension to freeze the boom or let it jybe. Love it! No more crash jybes.
Jim
I vote for the Dutchman Boom brake I have one and its is fail safe. Should I get another boat it is one item I will make sure I get the same.
Related Threads
1.7M posts
173.8K members
Since 1990
