SailNet Community - View Single Post - Repairing leaks?
post #8 of Old 09-12-2006
You can always hire a qualified marine surveyor to put a moisture meter on the deck. That is really the only way to know if the leaks are something that can be repaired with a few tubes of caulk and maybe a weekend epoxy project or an outrageously expensive project to replace the balsa core in the deck. For an investment in the boat, the $300 or so that it costs is probably well worth it. A professional broker should be able to provide a list of several to chose from. If not, try calling the largest repair facility in your area. They probably work with a few they can recommend.
Lecy is offline
