SailNet Community - View Single Post - Help with Johnson 4hp carb
post #6 of Old 01-01-2012
travlin-easy
travlin-easy's Avatar
The linkage connections are missing, at least from what I can see. It appears as if someone jury-rigged the linkage with a length of string. The spring is a return spring, which is used for slowing the boat down. You should be able to find a repair manual on line, and it will have a parts list with OMC numbers, which back then were the same for Johnson and Evinrude.
Good Luck,
Gary
travlin-easy is offline
