Old 11-15-2000
paulk's Avatar
paulk paulk is offline
paulk is on a distinguished road
Hunter 42 - at sea
Certified what? By whom? The Hunter 42''s that I''ve seen may be nice boats, but that does not necessarily make them suitable for ocean crossings. Think of one upside down on a wave. Are ALL the lockers fitted with latches that will hold them shut with the full weight of the contents pushing down on them? Will the tanks stay where they were originally built? Will there be an oil leak that makes the carpeting slippery and its smell sickening? Are there handholds every two feet or so across the underside of the cabintop? Are there storm covers for the ports? How do they mount? How much "sail area" do the cabin and topsides offer to 50 knots of breeze, and how fast will that make the boat go in a direction that may not be the one you desire? Are there large, flat surface areas with little support in the deck, cabin or topsides for waves to work on? Tons of water pressure on these areas can result in their flexing, fatigue, and failure. While I am sure Hunters have made long trips, they might not stand up to the rigors of long distance cruising as well as some other designs, and their shortcomings in this regard may take a toll on you as well. Other boats do offer similar setups, and MAY be a bit better put together. You may want to look into a C&C Landfall 43, a Gulfstar 40 (and 42, I think), and (though it will be out of your price range) a Hylas 47.
Seeing models of these of varying ages will let you see how they each hold up to the use they''ve been put through, and how they might hold up to what you plan to do. You can then compare them with the Hunter and have a better idea of what you''re getting into. A lot depends on what you want to do with your boat. You may find that a 15 year-old Hylas, used hard, is in better shape than a 5 year-old Hunter, used less. Hmmm. You may find that the Hunter is perfect for what you plan. Happy hunting!
