SailNet Community - View Single Post - Shroudless Masts
post #16 of Old 01-06-2012 Thread Starter
PsySailor
Originally Posted by smurphny View Post
It would be great to be able to do away with all the problems with swages, turnbuckles, corrosion, and rig tension but this technology is still in the experimental stage. One of the towing companies around LI Sound tried to kedge one of these off by the mast and wound up snapping it. It was a carbon fiber mast and, from what I heard, prohibitively expensive to replace. So apparently kedging yourself off by using the mast to heel the boat over is a tactic removed from the book of tricks with one of these.
Sounds like they were not too bright. It's a different technology, not experimental. If you don't know what you're doing, your bound to make mistakes... Just like with anything...
PsySailor is offline
