SailNet Community - View Single Post - The final solution - what I came up with regarding auxiliary propulsion (pic heavy)
post #16 of Old 01-10-2012
Ajax_MD
Chastened
Ajax_MD's Avatar
Originally Posted by dabnis View Post
Chris,
Wondering what effect taking out maybe 300 to 400 pounds from way down low and adding 50 or so pounds way back and up high might have on the sailing characteristics of your boat? Maybe making it a bit tender? Seems like a big change in the overall design function? If you can find someone that has made the same change it would be interesting.
Dabnis
The void where the engine was, probably will not remain empty. He'll load it with gear which will probably offset the missing weight somewhat.
Now that I'm home, the gear looks solid, and well-made. I really encourage you to look for a 5 - 8 hp TWO-STROKE outboard. It'll be very light and give you a better push against an adverse current. If you're going for a 4-stroke engine, then yeah, 4hp is probably your weight limit.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
