SailNet Community - View Single Post - Yorktown
Thread: Yorktown
post #16 of Old 01-17-2012
i was under the impression all models had the hull deck joint glassed, as my 39 is. the leaks are probably coming from the covering/rub rail that was screwed over the seam to hide it. a bit of work to remove and rebed...assuming the po used 5200 or the like. accessing all the nuts will be tough. ive soaked a leaky area with soapy water, turned a shop vac around and had someone on the inside to see which fastener is blowing bubbles. just an idea...good luck
robwilk37 is offline
