SailNet Community - View Single Post - composting toilet report
post #349 of Old 01-17-2012
ewoden
ewoden's Avatar
Originally Posted by pdqaltair View Post
I've used this computer fan in the head and also in a compost/biofilter system on some pet cages. It should last ~ 2 years continuous duty in this humidity.
Sail Delmarva: "A Bathroom Fan": or "No Blog Could be Complete Without a Tale of Head Repairs"
Solar vents would certainly work, but $$$.... In my case, I already have enough panels. Screen the outlet for ....
Yep I scored a small 40mm on a side, <0.07A fan from local Microcenter. She's a weeee tiny little thing, 5 cfm at 3200 rpm. Judging by the prototypes low, Ahem, signature I figure a few head box volume exchanges every 5 or ten minutes ought to t=do nicely. In my first vent attmpt I'll run an air flow through tubing the size of the existing holding tank vent on the boat as that will be my preferred method on board if it will maintain enough airflow out of the boat. Since this little fan draws so little, I'll atempt power first by a small solar charger. If that fails, then connection to house power via the old recirculating head pump circuit. If the little fan proves insufficient, then a bigger fan (i have several computer pullouts, as either solar ventillator or computer fan connected to the old pump-out fitting with a 1 1/2 npt elbow rigged to keep things dry.
A ship in harbor is safe, but that is not what ships are built for.
William Shedd
ewoden is offline
