SailNet Community - View Single Post - Tapered Mast vs. Standard Mast
post #28 of Old 01-19-2012 Thread Starter
gadangit
Originally Posted by Chris12345 View Post
A tapered mast is much better than a straight one, either lighter at the same strength, or stronger at the same weight. Tere is a reason racers pay for them through the nose.
Which of the two advantages yours has you can easily guess if it is a raceboat.
What is your problem with the rod rigging? If it is good, leave it alone!
You can carry a replacement wire, no need to carry a replacement ROD.
One wire that's longer than the longest part of your rigging, and as strong as the strongest (i.e. most likely a second forestay) , plus two do-it-yourself end fittings, and you are set.
I definitely considered your points about the mast! Having raced a car in the past, I understand the situation. And the boat I crewed on was definitely under way more stress than someone casually cruising. The point is becoming moot, I made an offer on the other boat which is coming with more gear. They are both holes in the water where I will throwing money for a while...
Thanks everyone for your excellent insight.
Chris
gadangit is offline
