SailNet Community - View Single Post - stability issues by modifying
post #2 of Old 01-21-2012
WDS123
Yes, the stability is changed. the critical question is by how much.
There isn't a simple answer, because it depends on the weight of the boat versus the weight of the respective engines, plus one would like to know distances the load is moved both in the x and y dimension.
If you give some specifics, people here could help you or at least give a rough idea.
WDS123 is offline
