Old 01-23-2012
sea_hunter's Avatar
sea_hunter sea_hunter is offline
Senior Cruiser
sea_hunter is on a distinguished road
I help a friend install one on a 42S. I was at first skeptical installing a staysail on a in mast main, but B sail all was good. They liked the idea of using the windlass bulkhead to fasten the chain plate. We removed the winch, installed the plate and added longer bolts with little modification. You'll need a rigger to install topside of the furler fitting, just above the spreaders. Needs to be drilled and tapped, but B says okay. I'd give them a call to make sure your specific model and supplied equipment will allow this modification without changing the mast or something drastic.
