SailNet Community - View Single Post - Perkins 4.154 Crank Pulley removal
post #12 of Old 01-25-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Originally Posted by sea_hunter View Post
Yes automotive serpentine belts require a loaded tensioner, the ones used on marine engines employing large case alternators do not. The belt goes around ALL the drive pulleys, but underneath the idler pulley. The tension is loaded with the alternator adjusting arm. The main reason it's done this way is that marine diesel engines don't operate at variable and higher engine RPMs (therefore no backlash that causes the belt to "jump") like automotive engines. Hope that helps.
Thanks - good to know.
SloopJonB is online now
