post #1912 of Old 01-29-2012 Thread Starter
New boat: The OVNI evolution 52.
That's a true revolution on OVNI, the most famous bluewater French boat. The new series are still aluminum centerboarders but they have abandoned their overall conservative design to present a true modern line based with the hull based on the shape of solo Open boats, a Marc Lombard design.
Also for the first time they present the possibility of a completely closed dog house an ugly one in my opinion. But if we don't consider that this is a good looking boat that for the first time show lines that are not very far away from its more sportive cousin, the Cigale 16.
Some interesting solutions: The wheel can be on the usual place or more at the center, inside the dog house, the boat has a garage for a dinghy with 3.10m and utilizes the same interior solution as the Benetau sense, meaning that the boat has no properly aft cabins (just a very small one to sleep while sailing, I mean for an eventual skipper) and that all the space is used for the garage and storage.
The announced price is around 500 000€ and that don't seem much for an aluminium boat of this size.
A 47 footer will also be made along the same lines.
Of course, in what regards the Cigale 16, that is just a bit longer and is also made by Alubat and designed by Marc Lombard, this boat just seems more like a Cigale than the previous OVNI but the differences between the two boats in what regards sailing are HUGE. Just to give you an idea this one weights 16 000 kg, the Cigale 16, 10 750kg. Both boats have about the same sail area (the Cigale has a bit more) and the Cigale has less 5 250kg. You can imagine the difference specially in what regards going downwind over hull speed and sailing with light winds
But if the Alubat 52 will be slow if compared with a Cigale if we compare it with the Benetau Sense 50 the story will be other: The Sense is smaller weights about the same ( less 700 kg) but has less 13 m2 of sail and that and a smaller LWL will made the Ovni faster in all points of sail except probably close upwind and of course with the possibility to avoid bad weather staying on anchor in very shallow waters.
