Hunter 42 - at sea
With regard to the certification process, as the European Union has been coming together they have tried to develop uniform standards that would apply to inter-country commerce. These standards have been applied to everything from butter to boats. The process of developing acceptable standards for boats has been ongoing for the better part of a decade that I know of.
The original standard dealt solely with stability and downflooding at sea. The process was very interesting in that yacht designers from all over the world were consulted as well as research teams. Data was collected from a wide variety of events (knockdowns and roll overs) as well as from actual disasters. The events were plotted against the known information on the vessels that had been through dramatic occurances. Certain patterns were noted and a set of formulas were written that attempted to create an empirical rating regarding a boats safety at sea only as pertained to knockdowns and roll overs. The grade that resulted would have placed vessels in one of four categories, with the most stringent being ''Open Ocean''.
These formulas were submitted to member nations for review, comment and approval. As a result of this multi-European nation over view the formulas were changed so that they required simplier information to obtain essentually developing surogate approximations (For example instead of requiring manufacturers to calculate the vertical center of gravity of the boat, a computation of draft, ballast, mast length and displacement was used roughly estimate the vertical center of gravity- a poor substitute but easier to obtain.) The requirements were also reduced in severity as well.
Shortly after the stability standards came a set of equipmentand systems standards. These do have some minor scantling requirements.
Hunters larger boats were some of the first to be certified for an "Open Ocean" rating. You can argue with the stringency of the rating (which I do) but you can''t argue with that they did not obtain it. Hunter''s current crop of larger boats have CE Open Ocean certifications.
Now to correct one point above, these certified designs have been altered to obtain the necessary certifications. One reason that Hunter went to cored topsides was to reduce weight to allow them to have additional ballast and thereby do better. They also raised to cabins to reduce inverted stability (a major category in the standards) albeit hurting real usable stability by raising the center of gravity and adding windage.
In any event, the standards do not really cover the characteristics that determine whether a boat''s capability really is as a blue water boat. It does not look at seaberths, handholds, size of portlights and thickness of large plexiglass elements. It does look at hold downs and system installations. It does not consider comfort of motion.
In conversations with Hunter owners who have weather storms at sea you get all kinds of mixed messages. The boats, by and large have survived but they have flexed terribly. I have read accounts of dislodged bulkheads and casework. I have experienced failed fitting attachments. I have experienced blown up or damaged undersized hardware. (We have had two Hunters in my family.) Hunters are a mixed bag but in my mind most of the newer boats are not a boat that I would choose to cross an ocean on.
Respectfully,
