SailNet Community - View Single Post - a (semi) happy (almost) ending to my saga
post #11 of Old 09-24-2006
EagleSailtwo
Sorry to hear all this, but as mentioned by others, you need to act on this asap, like starting Monday morning! That marina is screwing around with you for sure!
A drop of water entering any of the firing chambers would likely cause a hydro-lock situation and stop the engine. You couldn't get the amount of water necessary to cause heavy rust of cylinders walls buy running the engine, it would have hydro-locked first.
Cranking a stubborn to start diesel (below water line types such as most sailboats) should only be done with the engine raw water in-let seacock closed, just don't forget to open the seacock once the engine fires off!
EagleSailtwo is offline
