SailNet Community - View Single Post - Air Draft vs. Bridge Height vs. Heel
post #9 of Old 02-07-2012
Rockter
Your trigonemetry is correct.
The heel angle needed for the 19 ft bridge clearance is given by...
a = invcos{19/25} = 40.53 deg
...and for the 21 ft bridge clearance...
b = invcos{21/25} = 32.86 deg.
Those are first estimates, as the mast will not pivot perfectly around a single point as the boat heels.
Those are quite aggressive heel angles.
It's a risky business though. If you get it wrong, you will smash the masthead and fittings on the bridge. You may even bring the mast down.
Rockter is offline
