SailNet Community - View Single Post - Replacing secondary filter on Yanmar 1GM10 diesel
post #2 of Old 02-08-2012
HUGOSALT
Yes...filters to use primary 30 microns (I use R 20P 30 micron)
secondary 10 microns (yanmar # 104500-55710)
Above are specs as per Mack Boring a large yanmar distributor.
Instructions how to change racor replacement element are printed on side of element.
I have used the screwdriver and pound method to remove ring
from secondary filter but as of late I use a pair of slip joint tongue
and groove plyers or can use a filter or belt wrench if will fit.
Can use filter or belt wrench for racor element as well.
Must bleed system after changing filters.
Hope this helps,
Hugo
HUGOSALT is offline
