SailNet Community - View Single Post - Storm trysail question
post #13 of Old 02-09-2012
SVAuspicious
Mermaid Hunter
SVAuspicious's Avatar
Originally Posted by killarney_sailor View Post
BTW, I don't think I can tie my boom out of the way on deck since it has a rigid vang.
I have a rigid boomkicker also. I slide the traveler all the way to one side with some slack in the main sheet. I use a dock line to pull the boom as far to the opposite side as possible. Then I grind the main sheet in to hold the boom. Works a treat.
As far as loads are concerned the load that the block will see may be up to twice the sheet load depending on the angles in and out of the block.
SVAuspicious is offline
