SailNet Community - View Single Post - 1983 C&C 29 Mk11 Keel Bolt Question
post #8 of Old 02-15-2012
RobGallagher
HANUMAN
RobGallagher's Avatar
Originally Posted by msmith10 View Post
On my C&C30 Mk 1 I believe there are 4 keel bolts (maybe 5). What I'm sure of is they are 1" diameter and are torqued to 350 ft lbs.
To actually torque them to specs, you'll need a deep well 1-1/2" socket (if the bolts are 1") and a torque multiplier or one heluva big torque wrench. I actually bought a torque multiplier and the deep well socket to allow use of my 1/2" torque wrench with 3/4" adapters to fit the socket and torque multiplier. It cost me about $175 for the tools.
If I had it to do over again, I'd let the yard do it, although I don't think they had the tools anyway.
They really needed it. They were just beyond hand tight and the C&C smile required yearly patching. Since torquing to specs, the smile has not reappeared.
Check around and you can probably rent a +size torque ratchet and sockets. I got them at my local Ace hardware rental.
The info for all older C&C models is on the CNCphotoalmum.com The torque fl/lbs is listed by bolt/stud size.
KEEL BOLT TORQUE SPECIFICATIONS
MODEL SIZE BOLT DIAMETER FOOT POUNDS SOCKET NUT
MEGA ONLY 3/4" 90 1-1/8"
C&C 40 1-1/4" 450 1-7/8"
ALL OTHER 1/2" 80 3/4"
MODELS 3/4" 250 1-1/8"
1" 350 1-1/2"
RobGallagher is offline
