tank problem
The fastest and easiet way to handle your problem would probably be to hire a fuel polisher to come out and polish the fuel. It would require having a second access port into the tank, but this is generally not too big of an issue requiring a hole saw and vaccum. Generally a 2 or 3 inch hole would do it, then screw a port over the hole.
At least then you are in a known good state and the racor should handle it from there.
After that point always use a good fuel conditioner.
If the problem continues, you can install your own polishing system with just another racor, a 12 volt fuel pump, hose, and a couple of Ts. Let the polishing system run while you are just hanging out on the boat.
Good luck with it.
