SailNet Community - View Single Post - Palmer 60 troubleshooting
post #3 of Old 02-20-2012
CalebD
Tartan 27' owner
CalebD's Avatar
Most likely the float needle valve is stuck.
A quick fix involves tapping the float bowl with a screw driver handle (works on an Atomic 4 Zenith carb).
The main cause can be crud in your fuel supply. Check or pump out your fuel tank. Look for E10 phase separation floating under the fuel.
Everybody has one:
CalebD is offline
