Hunter announces electrical concern on P42
(From the Hunter Owners Buletin Board)
Hunter Marine has released a memo to owners of Hunter Passage 42 owners with hulls HUNP0001J990 through HUNP0180L495, stating that certain electrical upgrades could cause a fire hazard.
Because of a fire on a 1994 Passage 42, Hunter initiated an investigation of its wiring. While their memo lists many possible causes of this fire, including improperly installed after-market equipment, they concluded that the charging leads and isolator wiring inside of this model may not be adequate for some of today''s add-on equipment.
As a result, Hunter is offering a free wiring upgrade to owners of boats with the serial numbers listed above, picking up the cost of both parts and installation.
If you own one of the boats in question Hunter recommends that you not leave the boat unattended for any reason while the dockside power is attached to it, and that the
inverter''s battery charging system not be used during nighttime hours.
While many 42''s have been upgraded and no longer have the original
inverter, isolator switch, or wiring, you should still call Hunter Marine immediately to determine if your boat needs this upgrade. They will provide complete instructions on the upgrade, and can help you determine if your boat requires it.
Hunter Marine can be reached at: 1-800-771-5556
..or...
huntermarine@worldnet.att.net
