SailNet Community - View Single Post - Which Anchor?
Thread: Which Anchor?
post #3 of Old 02-24-2012
killarney_sailor
Bristol 45.5 - AiniA
I have a Mansom Supreme (they make other anchors so I a not certain that this is the one you are referring to) and have been very pleased with it. On the other hand, one big advantage of the Fortress is lightness, including the fact that they do not recommend a great deal of chain be used with their anchors. They are good anchors and the light weight is a consideration.
If you plan to use an anchor roller make sure that the anchor you want to use will fit nicely on it. One advantage of CQRs and Bruces is that they fit on rollers well. With some of the others you have to experiment to see.
Back home on Lake Ontario after something over 36,000 nm circumnavigator. Not surprisingly there is a lot of stuff I want to get done on Ainia both cosmetically and functionally. Getting an early start so it will be ready to go for next summer (Lake Superior?).
killarney_sailor is offline
