SailNet Community - View Single Post - Stuck Knotmeter Paddle Wheel
post #6 of Old 09-30-2006
sailingdog
IIRC, the paddle wheel just spins in the bushings, and isn't physically connected to the electronics (believe they use either Hall effect or magnetic sensor) via gearing of any sort...so replacing the paddle is pretty easy. In many cases, you can remove the pin and then clean the paddle and the housing, and then replace the original paddle.
sailingdog is offline
