SailNet Community - View Single Post - Where to start, what to buy.
post #9 of Old 09-30-2006
sailingdog
You and your wife should both be capable of sailing the boat single-handed, as that is essentially what you will be doing if you cruise as a couple. The boat, regardless of size, should be rigged to be single-handed. I would go with a 30-35' boat, rather than a <30' boat, as it will be far more comfortable for you, and not all that much harder to handle than a smaller boat. Anything larger than 35' is going to be a bit too much for you, especially given your limited experience.
You and your wife should both take a good "coastal cruising" course, but I would recommend that you take them separately, rather than as a couple. In many cases, when a couple takes a cruising course, one of the couple will often learn far less than if they had taken them seperately, since one will often defer to their spouse.
Also, join a local yatch club and race or sail there, as a season of sailing on a racing boat will teach you a lot more about sailing than a season of just sailing by yourself. Also, the techniques you learn about tweaking the performance on a racing boat will be useful when you're sailing a cruising boat in light winds and need to maximize performance.
sailingdog is offline
