SailNet Community - View Single Post - Are davits a safety issue for coastal cruising?
post #12 of Old 02-27-2012
Originally Posted by billyruffn View Post
.. In rough conditions -- Stow it!...
That's a very good advise. Let me add that many that say that Davits are dangerous sail happily with the tender on the bow, that is one of the two places you can store a dinghy on a 36ft or smaller boat, if you don't have davits.
Having it on the bow is probably as dangerous or more than having it on davits. If you have a problem on the front sail or need to change for a storm sail the dinghy makes it dangerous to go and stay forward working.
The other place is back on the stern, firmly attached to it. I found it better and more safe that way. Waves are not a problem but in my boat it obstructed partially the back navigation light and I found out that over 40K wind the windage is so big that it can seriously compromise the ability to control the boat: With that wind a light modern boat is sailing with less sail area than the one that is provided by the flat dinghy on the back and the problems are obvious.
So, as Billy have said, unless you are sure of having tame conditions, stow it while you sail. A easily roll up dingy is a must on a small boat and the new ones with inflated floor are a very good idea.
