I don't know if the aluminum layer in a CD is thick enough to reflect a radar signal...given that the mast on a sailboat does a pretty piss poor job of it, and is generally much thicker aluminum... BTW, the reflective layer is aluminum, not silver. Silver is probably a better radar reflector than aluminum, as it is a heavier element. Lead is probably even better.
Granted, angle of reflectance matters, and corners seem to generate a much larger return than smooth rounded surfaces...I'd still go with a Davis Echomaster over a pile of AOL CDs—but they might work if glued in a shape made of multiple tetrahedrons...
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
