SailNet Community - View Single Post - Disposing of Bow Pulpit ?
post #10 of Old 10-01-2006
Faster
The bow pulpit is the stainless steel "railing" at the bow of your boat. The photo is of the stem head fitting, in this case it looks like a cover plate.
If, as I suspect, your mast is deck-stepped (ie - it doesn't extend into the cabin, resting on the keel) then it will fall over if you disconnect your forestay.
You need to get some qualified advice before you go further!
Faster is offline
